MODM7AE70 - uart max baudrate
Posted: Tue Jul 12, 2022 1:32 pm
by rogerio.c.labanca
Hi all,
I want to know the maximum baudrate that I can configure using the MODM7AE70 serial ports.
Re: MODM7AE70 - uart max baudrate
Posted: Thu Jul 14, 2022 6:25 am
Not as simple a question as one might like.
The baud system can divide by 8 or 16 and have a fractional component.
CPU Clock is 300MHZ.
The Perif_clock is also 300Mhz.
The baud rate setting code is in:
nburn\arch\cortex-m7\cpu\SAME70\source\serial.cpp
So I think the baud can be set as high as 37.5 M baud.
(Perif_clock / 8)
What baudrate do you want?
Better question is I want baudrate XX what is the error at that rate?
Posted: Mon Feb 26, 2024 11:19 pm
by Ushavilash
The maximum baud rate for the MODM7AE70 serial ports depends on specific hardware configurations and firmware settings.
Posted: Tue Feb 27, 2024 4:29 pm
Are you saying you do not know what specific baud rates you need? Or the maximum?
Posted: Thu Feb 29, 2024 12:22 pm
Hi Rogerio,
Just checking back to see if you have an idea of the baud rates you need.
