Can I use J-LINK Debugger with MODM7AE70 ?
Anguel
Post by Anguel »
I wonder if a professional-grade debugger like J-LINK can be used with the MODM7AE70.
How about J-TRACE?
Anguel
lgitlitz
Re: Can I use J-LINK Debugger with MODM7AE70 ?
Post by lgitlitz »
The MODM7AE70 was not designed with the intention of using an external hardware debugger. Debugging features you would use an external debugger for can be done with the GDB network debugging tools... ie breakpoints, stepping through code, watching memmory or variables, ext. Is there some type of debugging functionality you need that is missing from the provided network debugging tools?
