CB34EX-100ir
vijay5264
CB34EX-100ir
Post by vijay5264 » Fri Dec 15, 2017 1:46 pm
Hi All
I am new to this forum and whole NetBurner hardware I have CB34EX-100IR and trying to connect to it via IP address after flashing latest firmware (installed without any problems) downloaded from
https://www.netburner.com/cb34ex onlu
problem is i am not able to detect any IP address via update utility or IP setup utility
any other options to connect to it ?
or to re flash it (if that might cure the problem)
Thanks in advance
Vijay
Re: CB34EX-100ir
Post by TomNB » Fri Dec 15, 2017 3:48 pm
Can you provide details on how your network is set up? Do you have a dhcp server?
You should see status data on the db9 when using a serial terminal such as mttty.
vijay5264
Re: CB34EX-100ir
Post by vijay5264 » Sat Dec 16, 2017 3:23 am
Hi Tom
Thanks for quick reply I was up to now only trying to connect via network so far I will connect to serial while booting up and report back later today and hopefully will give me insight in problem.
also is there a way to install firmware via serial ?
Kind regards
vijay5264
Re: CB34EX-100ir
Post by vijay5264 » Sat Dec 16, 2017 7:09 am
Hi
After connecting serial with Mtty i can see device booting up and keeps rebooting it is showing network information (all 0) it is trying to get Ip address but before it can it just reboots and stuck in loop.
after pressing shift A few times it lets me in but reboots before i can type any thing .
any ideas how to stop it from rebooting ?
Thanks in advance.
vijay5264
Re: CB34EX-100ir
Post by vijay5264 » Sat Dec 16, 2017 8:02 am
Sorted
after changing reset time from 2 to 20 it is not working.
now starts the task of making it work with can bus from car ecu
Idea is to turn it in to high speed data capture device from ECU to onboard laptop via network (i would like to see it working with wireshark)
Thanks a lot
